Ir para o conteúdo principal
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Perguntas Visualizar todos
Stripped Screw on Antenna Plate
So just as the description says, when putting one of the hex screws back in on the antenna plate, I over tightened and stripped one of the screws. And when I say stripped, I mean I stripped the threads, the screw just spins now and doesn't hold, it just falls out. Is there any solution for this?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Were you able to solve this problem? I'm having the same issue
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Usually it's possible to grab the screw with a pair of needled nose pliers. If not, you might have to drew the screw out using a drill.
Hope it helps!
Esta resposta foi útil?
Pontuação 2
There's some really cool pliers designed for just this problem!
Screw Extracting Pliers
Imagem de Screw Extracting Pliers
Produto
$19.99
Pontuação 2
4 comentários:
Its not the hex part thats stripped, its the threads female threads that are stripped.
por
To get it to hold back in place, you can always try using some Loctite or another type of threadlocker. Just don't get the super high strength stuff, or you'll do more damage.
por
Thats kind of what I was thinking...Guess I'll give that a shot.
por
Were you able to solve it? I have the same problem
por
Adicionar a sua resposta
betts211 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 407
