Ir para o conteúdo principal
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Perguntas Visualizar todos
Sound receiver replacement. Other people cannot hear me.
Hello
I recently drop my phone into the water. Everything work beside the sound reciever, now I can't call other people because they can't hear me. Where can I find the part? Where will replace this part for me?
Thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Other people can't hear you proves that your MIC is broken. The microphone of M8 is on the USB board, so you may need to try to replace M8 USb board at first.
That's the repair guide https://www.youtube.com/watch?v=QQjJkkok...
And that's the original replacement http://www.witrigs.com/oem-charging-port...
But if it still fail, you maybe need to check the motherboard connector. So hope the USB board replacement works.
Esta resposta foi útil?
Pontuação 0
My Htc e8 mic only works on speaker: other people can not hear me unless I turn on the speaker phone. What's the problem?
Pontuação 0
1 comentário:
I chatted with HTC guys and they claim custom ROM installed is the problem.
Any idea
por
If you dropped it into the water and dont open it up and clean all the parts with alcohol and an ultrasonic cleaner it will probably show more issues later on when corrosion sets in.
Pontuação 0
change the mouth piece
Update (10/15/2015)
change your phone's mouth piece
Update (10/15/2015)
Pontuação 0
Adicionar a sua resposta
jimmy wong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 3,400
