Ir para o conteúdo principal
Originally released in 2001, identified by model number VT750DC.
3 Perguntas Visualizar todos
The lights are not turning on but the engine is running.
When I start the motorbike, the engine starts up just fine, but the head lights do not turn on no matter what I do. How can I fix this?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Lights are not working
por
Adicionar um comentário
2 respostas
Pergunta mais útil
If the head lights are not turning on even though the motor is running, the bulbs may be burned out. Make sure they are screwed in all the way and check the connection wires to the lights. If this does not solve the problem, they will most likely need to be replaced. Please refer to the troubleshooting guide for more information.
Esta resposta foi útil?
Pontuação 1
Check bulb and fuses. Then check if power is getting to the bulb with a volt meter.
Mine has new bulbs and fuses along with power to the bulb, but still isn't coming on.
Pontuação 0
Adicionar a sua resposta
Daz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 324
