Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Pergunta encerrada
Finger print recognition failure
Hello Comrade.
I have an iPhone 5s 16gb gold. After replacing the home button with fingerprint recognition it doesn't seem to recognise any finger print. I cannot set any finger print or lock my device with the fingerprint security. Who might be knowing a fix to this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
You cannot replace the home button on the 5S and still use the fingerprint sensor.
The original sensor in the button is tied to the phone.
Esta resposta foi útil?
Pontuação 2
Robinson M, that is exactly what happens when your replace the home button. The touch ID sensor is designed to be secure and it is uniquely paired with each specific phone. There is no way to restore that particular function. Read more about that on here. and on here as well. "unique logic board in each iPhone 5S and the fingerprint data is stored on the A7 chip". Hope this helps, good luck.
Pontuação 2
1 comentário:
Old turkey..Thank you for the info..Thank you Aceman..Helped me understand
por
Update on this issue: Apple can actually fix this by replacing the display assembly, they are able to re-provision the security pairing. As long as you have warranty or willing to pay about $100, you can get it fixed.
Pontuação 1
Is the id in the actual button, or is it in the resistors mounted on the flex?
If its on the flex, would it be possible to transfer these over?
Pontuação 0
2 comentários:
This has been asked before and it is all basically too delicate - you would end up destroying it either way.
I wonder if Apple themselves are able to re-pair sensors and motherboards ?
Surely ?
por
Yeah...for the same price as a new phone they would!
I can imagine them pairing everything in the future :(
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 242
