Ir para o conteúdo principal
Capacitor replacing on iPhone 5
Hello.
I've replaced the "Audio Control and Power Button Cable", thank you very much for the step-by-step.
As I almost finished, my screwdriver slipped and I've removed a couple of capacitors (I think that's what they are).
Here is a picture, it's right next to the battery connector:
Can someone help me to identify so I can (hopefully) re-solder them?
Thank you.
Peter.
Update
Hello oldturkey03.
I'm just trying to see if these are the parts needed:
The manufacture codes are C0402C0G1C560J020BC for C279 and MMZ0402S121C for the FL11.
Thank you.
Peter.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Peter, that is reference designator FL11 is a 120ohm 210mA inductor in a 01005 package and
reference designator C279 is a 56PF 16V 5% capacitor in a 01005 package. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 5
6 comentários:
Hi oldturkey03. Thank you for the info. I'm trying to get the parts. £0.18 for a part and £12 delivery :(
por
Hello oldturkey03.
Thank you.
Peter.
por
Hi guys! where you buy this parts? please help me crushedrepepper@gmail.com
por
CRUSHED RED PEPPER, they are available at digikey.com
por
What does this look like on the iPhone 6?
por
Exibir mais 1 comentário
FL 11 is required and will have to get back in place for the phone to work. Honk if you need microsoldering assistance.
jessa
Pontuação 4
3 comentários:
Hi jessabethany. Thank you for the comment and support :)
I will probably need some assistance as soon as I get the parts.
por
Hi Jessa,
can you confirm me, that there are "unnecessary" parts in this section?
I ask because I ripped off 2 parts there, but the phone is working. Cant see any bug so far.
Maybe I ripped of 2 capacitors, that was used to smooth voltage-fluctuations, as I remember they are often near to power-supplys.
greetz revnu
EDIT: even if my assumption is right, what type of long term-effect I can expect bye missing smoothing-caps?
por
Have the FL11 and C270 pry damage on a 5C. What you will encounter is
- Battery gas gauge is incorrect
- Cellular call radio lose like 5-10dB signal strength
por
wow! you guys rock….
Pontuação 0
Adicionar a sua resposta
Peter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 15,312
