The light under key cap does not work!
Hello,
I have a problem with the light under the key caps.
Is there any way to replace or fix the light?
Thank you!
Esta é uma boa pergunta?
Hello,
Thank you!
Yes, there is! If the keyboard works as expected, and the only issue is that the light under the key cap isn't turning on, you can replace the LED under the key cap by following this guide. If there are issues with the keyboard other than the light, you can look at the troubleshooting guide.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 1,159
