Ir para o conteúdo principal
Help me to reasembly
Hi there! It's my first ask, so sorry verry much, if i post somethink wrong.
I have mobo and all those wires from A1226 Macbook:
https://www.dropbox.com/sh/mwaxjyoq0a6p3...
(Sorry for dropbox instead of build in file uploader, but i tried 5 times to upload getting unknown error ;/ ).
Can you tell me if it's possible, to make it works? I want to make it pc, so no need battery. Dvd isn't needed to. I'll buy some ssd drive, but i need to build this mobo from those parts. Can you help me, or edit my photos and paint what connect where?
And touchpad with keyboard isn't needed. I'll connect external devices for this. As screen i'll use dvi output.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Kiwiszon, this could be an exercise in futility. Lots of parts, not knowing what goes where and if those parts even work. I would suggest that you take a careful look at these guides. the guides should show you where most of these parts go and how they connect.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Kiwiszon,
How did you get these parts? Are you sure they belong together? You do appear to be missing some needed parts here. I don't think this is worth the effort to put together as you may have bad or incorrect parts for this system let alone the needed missing parts.
Pontuação 1
Adicionar a sua resposta
kiwiszon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 99
