Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
Pergunta encerrada
Internal speakers not working
I have an iPod touch 4 and my internal speakers are not working to play music or streaming, but sounds do play for example ring tones. I have reboot the iPod, but the iPod will only play through external devices. Any thoughts on what the problem could be and how to fix it?
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The ear jack could be faulty or it could be a problem with the docking port.
It sounds as though your iPod is in docking mode.
1) Clean out the docking port area carefully to make sure there is no dust or lint jammed in there.
Check for damaged pins, if you see bent pins then there isn't much you can do as the dock port is soldered to the main board and would cost you as much to replace the iPod as it would to fix the docking port.
2)If you are up to it, you can open the iPod and replace the ear jack. It is a small replaceable plug in jack so not a big job once you get inside.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 371
