Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Perguntas Visualizar todos
Can I replace a XGA screen with a WXGA screen?
My screen went out on my G4 Aluminum 17" A1107 - 1.67 GHz PowerBook. I cant seem to find a replacement screen for it because what i had was the XGA 1024 x 768 res lcd screen. Every where I look i find the WXGA 1400 x900 resolution screens and instructions on how to install it on my laptop. But I read some where that if the resolution isnt the same, the screen will not work. Is this true? Can I replace a XGA 1024 x 768 screen with a WXGA 1400 x 900 screen? If not, where can i find a XGA screen replacement?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
1024x768 on a 17" ??? - that can't be
12.1" - 1024 x 768
15.2" - 1280 x 854
15.2" - 1440 x 960
17" - 1440 x 900
17" - 1680 x 1050
if i remember right, your's should be the 1440x900 - but it can be replaced with the 1680x1050
there are sellers on ebay that will do the repair/change with the hi res lcd CLICK here
Esta resposta foi útil?
Pontuação 1
2 comentários:
well, the thing is, I am looking at my "about this mac" section and thats what its saying the resolution is. 1024x768. and i was told that you have to replace the screen with the same resolution screen or else it wont work. I am confused as well because everywhere online it says my screen should be 1400 x 900, but I dont think it is. and i dont want to buy a used replacement screen before i am sure about the compatibility. please help.
por
I think that the 1024x768 is the resolution of the external monitor - right? - and yes - it's a 1440x900 screen and could be replaced with the both 17" screens of the series
por
Adicionar a sua resposta
paul será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 1,753
