Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Whirlpool Washing Machine. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Whirlpool Washing Machine.
How can I address the F1 error code?
My Cabrio washing machine constantly stops during the wash cycle and shows an F1 error code. I hit pause and start at least 50 times over two hours to complete my wash. Is there a part I can replace so that my wash cycle operates properly?
Esta é uma boa pergunta?
Pontuação 12
4 comentários
An Luther then the f1 error code at the same time e9 appears an door will not open
por Compartilhar
i have a washer the front loader and when i press start it dosnt even do anything just f1
por Compartilhar
What if it just shows an f flashing?
por Compartilhar
Cabrio washer..error code F1 and E5. Unplugged for 15 min…then it blinked 888. Don’t know wha to do?
por Compartilhar
Adicionar um comentário
4 respostas
Pergunta mais útil
Usually, it's a problem with the control board. By replacing the control board, you should be able to fix the problem. However, it might also be a problem with the hose, something might be stuck in the hose. There is even a web site dedicated to the F1 error :) Whirlpool F1 Error web site. There you can find detailed instructions on how to check and clean the hose or if needed, replace the control board and also where to buy a proper one.
Esta resposta foi útil?
Pontuação 3
I had the same issue. I replaced the board and the F1 error was still there. I decided to put a hose clamp on the hose coming from the board. Boom my F1 error is gone. Hope this helps.
Pontuação 1
2 comentários:
I hope this is will work. Which hose is it?
por Compartilhar
It worked for me, my wife and I are very thankful for your post. I connected the hose, ran the diagnostic mode, fixed. We’re washing clothes!
por Compartilhar
Common, Water Pump. ( Clogged or Broken )
to get door to open, use wet-dry vacume to pull water out from washer, by vacumming water out from drain hose. ( the tube that goes to the hole in your wall. =-D)
Soap dispenser Missing Magnet sensor, or soap dispenser is not all the way in.
Motor control Unit is bad, or door lock solenoid is damaged.
Pontuação 0
2 comentários:
Drain pump. (take wet dry vac-vacume water out of washer through drain hose)
try machine again.) works( replace pump)
soap dispenser bad or half out.
bad motor control or door lock solenoid is bad replace door lock.
por Compartilhar
I have a Cabrio Washer, Replaced the Control Board and the washer wont do anything. I am at a loss.
por Compartilhar
A friend of mine had the same issue F1 code. We tried to unplug for 10 minutes and plugged it in about 6 or 7 times. We checked the breaker box a couple times, didn't realize one side of the double breaker was f##@ed. Changed out the breaker. No problems.
Pontuação 0
Adicionar a sua resposta
Bob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 29
Últimos 30 dias: 123
Ao todo: 95,958
