Proper One Plus One Display Replacement
Hello @ifixit , is there a more step by step process to replacing the screen? I have the replacement screen (LCD + Digitizer Piece) and I have seen the break down, but how do you put it back together exactly? if I just disconnect both of the screen connectors, would I be able to use the iopener to remove the screen,or do I need to remove the other components? also after you remove the screen with the iopener? Is there a proper way to attach the screen back? what kind of adhesive to use. thanks
Esta é uma boa pergunta?
17 comentários
Hi Mikel,
I broke my screen few hours ago. Can you tell me where you found your screen replacement ?
And did you managed to replace the screen ?
Thanks
por Bertrand Duthoit Compartilhar
This is is the screen I got, there were only a few options online. I should receive it next week and will comment on the quality then. thanks
http://www.aliexpress.com/item/Original-...
por Dev Mikel Compartilhar
Someone told me it comes with adhesive already so I should be good to go next week. I already know how to replace the screen from studying the breakdown. I will probably do my own how to video.
p.s. I also ordered a ifix it kit for taking some of the pieces off.
I disassembled my OPO yesterday watching the teardown. It was easy for the battery and all other back stuff. I tried to remove the screen and that was a fail. My glass is broken but the LCD seems fine.
I'm about to order this one since yesterday, I'll wait for your feedback then.
ok, I am expecting it in the next couple of days. what did you use to remove the screen?
Exibir mais 12 comentários
