Ir para o conteúdo principal
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
How do I print screen
I am using windows and I would like to print screens.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
If you have Vista or Windows 7, you can use the built in "Snipping Tool" to capture whatever you want on the screen. Click the start button and do a search for "Snipping tool".
Whatever you select (draw a box around) is automatically placed in the clipboard, which you can then paste into word or paint to print.
Unfortunately it doesn't allow you to print the screen directly. For this capability, I've used the program "Snagit" in the past. It also has a ton of other capture abilities. A trial can be found here: http://www.techsmith.com/snagit.html
Esta resposta foi útil?
Pontuação 2
Hello Robert. To take screenshots in windows simply click the Print screen button on your keyboard. After that open your paint and paste it there. If you want a easier tool in taking screenshots. I recommend my favorite tool in taking screenshots. You don't have to worry it is free and very easy to use. You may go to this link and try it: https://goo.gl/wkT6xv
Pontuação 1
1 comentário:
it was posted in 2014
por
Take a screenshot, go to files, and press print.
You can also do this...
Go to your browser.
Click the three dots in the top right corner
And press print.
Pontuação 1
Adicionar a sua resposta
Gary será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 920
