Ir para o conteúdo principal
Laser sensor, four buttons, trackball
15 Perguntas Visualizar todos
Purchase and replace ball
Something small and hard fell in the mouse track ball area and while i was pressing it (upside down) on a piece of paper to clean it, that little hard piece of dust, carved the surface of my track ball making it unable to scroll without jumping around!
So im now in the need of purchasing a new ball and replacing it! Does the ball as a part exist? Because i can't find anything on ebay! Any help?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Does anyone know how to find the provider of the scroll ball Apple uses to equip the Mighty mouse?
por
Adicionar um comentário
2 respostas
Solução escolhida
Sadly, the Mighty Mouse and the Magic Mouse are deemed as not repairable by Apple. You're only hope here is to see if you can locate a dead one to steal the part to make yours whole again or look into getting a new one.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Where can i look for a dead one?
por
eBay is a good start, local tech flea markets
por
genik, I am sure that you have already checked these instructions. Post an image of your trackball as well as the damage with your question and lets see if we can assist you finding what you need. If you can measure the diameter of the ball and let us know what you find. the scroll ball is nothing but a "rubber" ball with a metal core. I would suggest to measure the existing ball and get something the same (or at least very close to it) ball from places like this. Hope this helps, good luck.
update
any mechanic or machinist should be able to help you. All you need is a set of vernier calipers to measure it.
Update (01/06/2016)
I thought by now you had found what you needed. Anyhow, the diameter is 7.15mm/0.2815inch
Pontuação 3
6 comentários:
Hmm interesting, only i don't know how to measure exactly the diameter!
por
Is this tool offered in the Pro Tech Toolkit? Cause i see something similar... i think!
por
Has anyone managed to measure the diameter of the scroll ball?
por
genik, I sure would have thought you had it accomplished by now. I do have one left, so let me know if you want it:-)
por
You have what left? A scroll ball?
por
Exibir mais 1 comentário
Adicionar a sua resposta
genik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 542
