Ir para o conteúdo principal
Repair information and guides for MacBook Pro 15" Retina Display laptops from 2012 and continuing.
3614 Perguntas Visualizar todos
How much is a logic Board (I/O Board)
Ports not working on the right side; weak on the letter side Display flickering with lag Sound and screen lag occasionally Hardware making noise when starting up Display turns off and colors go negative occasionally
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Use the 'parts catalog'.
As you can see you've referred to 4 different models of machines... and the logic boards do not cross years.
The ports are connected to the logic board and generally beyond DIY soldering skills. A small electronics or computer repair shop may be able to re-solder them for you.
The easiest DIY repair (though still advanced as you have to completely dismantle and the reassemble your machine) would be to replace the entire logic board. An advantage to this repair is that if you have a base model machine you might be able to upgrade to the fastest model with maxed out RAM.
If you decide to replace the logic board purchase all the recommended tools (every job is easier when you use the right tools) and study (not just read) the correct guide and notes before you begin. Keep screws separated so you can put them back where they belong.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Awni Almasri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 471
