Ir para o conteúdo principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 Perguntas Visualizar todos
How to reset bios password
How to reset the laptop password?
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
3 respostas
Solução escolhida
greg, the password is stored in NVRAM, not in the regular CMOS settings. Removing the battery will not remove your password. For that you can either contact Dell or use your service tag to get the password.
Esta resposta foi útil?
Pontuação 3
2 comentários:
its doesnt show even where to enter the passsword ... why?
por
Salvis Krofts I am not sure I even understand your question. You really should elaborate on what you are needing.
por
take the motherboard battery out, for like a minute or so. That will make the bios run out energy and will make you load bios defaults. you will need to set time and date correctly after that.
Pontuação 0
2 comentários:
hello,i have the same problem and i took the bios battery for days but still asking for the pasword
por
The normal answer is to use service tag or administrator password...No answer for both even after trying F2 or F12. The 2 numbers on the back don't work.
por
hey i have dell inspirion 1525
my hard disk block with password
system Number :DPWN4BS-595B
PLEASE ANY ONE HAVE SOLUTION
PLEASE SENT ME MAIL @ vijaymhaske77@gmail.com
Pontuação 0
1 comentário:
8CSLK3-595B dell inspirion 1525
marouanrahire61@gmail.com
por
Adicionar a sua resposta
greg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 6,099
