How do I replace the Inverter
how do I replace the inverter?
Esta é uma boa pergunta?
take the upper cover, unscrew the hinges. be careful to disconnect the wifi antenna cables and the lvds cable. take the screen out of the chassis now. on the screen bezel, under some rubber feet there are screws, this screws, along with plastic clips hold the bezel. take them out. you are in. now is just disconnect some cables and you are good to go
Esta resposta foi útil?
Peggy, check this video. At around 1'30" you can see the inverter.
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 259
