Ir para o conteúdo principal
Repair guides and support for computer monitors produced by Samsung.
Slow turn on LCD display. How repair?
I have 2 LCD monitors.
Samsung SyncMaster 225BW
If I turn on, I must wait 10 minutes if they start.
I think something wrong with capacitors.
Do you know how can I repair it?
Thank you very much for answers.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Ladislav Lencses, use this guide to disassemble your display. Then check the capacitors on the power board. Check for any leakage, bulging etc and see what you find. Capacitors can of course fail without any visual indication as well. So, unless you have a tool like a capacitance meter, you may want to consider to replace the capacitors by using a complete kit like this one. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ladislav Lencses será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 3,011
