Where the memory is stored on the motherboard?
I'd like to know where to memory is stored on the motherboard and if it's possible to replace it ?
Thank You !
Esta é uma boa pergunta?
Thank You !
Sylvain, the memory IC is C-NAND FLASH;SDIN4C2-16G-944D,16GBYTE (varies depending on your memory),4 reference designator is UME6001. If you post a couple of Hi-Res images with your question, we can point it out for you. Here is the guide for adding images. Hope this helps, good luck.
Esta resposta foi útil?
Hi Oldturkey03,
Thanks a lot for your reply. I will post an image later since I'm doing this research for my sister and don't have her tablet yet.
If i understand you well, the memory chip is located here ?
https://d3nevzfk7ii3be.cloudfront.net/ig...
Here's what I'd like to know. Her motherboard is broken and she's has precious photos she'd like to restore. Based on what you know, could I buy an exact copy of her motherboard and replace the memory chip with hers ?
Thank you one more time
Sylvain
Sylvain, only if you know how to reball a BGA IC.
Do you under the iron place thing
i guess so if there the same motherboard
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,614
