Ir para o conteúdo principal
O Sony Ericsson K810i faz parte da linha Sony Ericsson e possui uma câmera Sony Cyber-shot de 3,2 MP. Lançado em fevereiro de 2007.
keypad not working propperly
The 1,3 and 6 keys aren't working.i have updated the phone software,and they start to work but only for a day,and since then they have worked from time to time.what could be the problem???
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Have you dropped your phone? Could this be the cause?
por
Adicionar um comentário
1 resposta
Solução escolhida
many SE phones have those problems - but sometimes different causes.
  1. fluid damages
  2. problems with the memory card (sounds stupid - but in fact, they are sometimes the troublemaker)
  3. defective keyboards
  4. bad connection to the logic board
the first step would be to remove the memory card - if it works after that - be happy - you didn't have to open the phone - if not - the fun will begin ;-)
get the proper tools and open the phone, check it for fluid damages, if everything is ok, check the keypad connector - reseat it (unplug/plug it in) and reassemble the phone - if it works, great - you just saved yourself 9.99$, if not - go to ebay and order a new keypad for 9.99$ (i think you know what to do with it when it arrives ;-) )
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
darko será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 5,735
