Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
5S Finger Scanner Tear Down
Has anyone attempted to replace the metal ring around the finger scanner?
I was unable to find any info on this, I'd like to offer this as a custom service, I'd be great to get some guidance without wrecking a few of em first.
I think a gold metal ring on a black scanner would be nice ;)
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
Andrew, just because the part is available does not mean that it can be replaced without sequela. The touch ID sensor is designed to be secure and it is uniquely paired with each specific phone. There is no way to restore that particular function. Read more about that on here. and on here as well. "unique logic board in each iPhone 5S and the fingerprint data is stored on the A7 chip" I am with Tom and con, don't do it. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
1 comentário:
thanks for providing an informative answer OldTurkey!
por
You WILL destroy the sensor and once you destroy it you will lose Touch ID FOREVER, don't ever attempt it.
Pontuação 1
No it cannot I would just let this idea go..
Is it worth destroying someone's touch id?
Pontuação 0
3 comentários:
im not going to wreck a customers, you can order the assembly for around $25, just hoped someone had tried before I delve into it. thanks for the advice....?
por
Shows how much you don't no bout iPhones once a touch scanner is broken A replacement will only let you click the button but it will lose touch id
por
you can purchase replacement finger scanners, this isn't alien technology, its a placeable part.
por
Adicionar a sua resposta
Andrew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 261
