Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
How to remove the all bolts of thermostat
how to remove the all bolts of thermostat nissan altima 2002 3.5l.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
consueloscott1972, I am a bit confused by your question. I am wondering which bolts you are referring to.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
consueloscott1972, try this:"
Before servicing the vehicle, refer to the Precautions Section.
Drain the cooling system.
Disconnect the negative battery cable.
If equipped with an engine undercover, remove using a power tool.
Remove drive belts
Remove water drain plug on water pump side of the engine.
Disconnect lower radiator hose.
Remove engine coolant inlet and thermostat assembly.
NOTE
Do not disassemble engine coolant inlet and thermostat. Replace them as a unit, if necessary.
To install, reverse removal procedure.
NOTE
Install thermostat with jiggle valve facing upward.
Fill the cooling system.
After installation, run engine for a few minutes and check for leaks.
From here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
consueloscott1972 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,919
