Folder with question mark
Booted with USB boot device and in disk utility showing ip as 217 GB checked with known good HDD still the same suspecting the PATA port failure.
Need your suggestion in this can be repaired or need to replace the MLB
Note: Checked with known good cable still the same reaction.
Esta é uma boa pergunta?
4 comentários
Can you give us the last four digits of your serial number so we can identify which model you have.
por Dan
MacBook Air "Core 2 Duo" 1.6 13" (Original)
por Dan
1.6 GHz Core 2 Duo (P7500)
Intro Date: January 15, 2008* Disc Date: October 14, 2008
Order No: MB003LL/A Model No: A1237 (EMC 2142*)
Subfamily: MacBook Air - Original Model ID: MacBookAir1,1
Std RAM: 2 GB Std VRAM: 144 MB
Std Storage: 80 GB (4200 RPM) Std Optical: None*
por oldturkey03
SN: y51
por vittal
