Ir para o conteúdo principal
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Perguntas Visualizar todos
Touch screen does not respond after glass replacement?
I cracked the glass on my phone. Functionality and everything worked fine. I decided that I was tired of the glass chipping away and went about changing the screen. Everything went well and the new glass was installed. The phone turned on and the screen looks great, but now the touching the screen there is no response. The back and home buttons worked. Voice command works. I removed the new glass and tried a new one with no change. What could this be? Any suggestions or tips would be great!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Take screen off and see does the touch work I have seen this problem before and it's to do with the glass being to high and not flush with the lcd you also need to use loca glue
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
it sounds like you did glass only? the digitizer is glued to the lcd and has to be replaced as one , it sounds like the digi was damaged in some way during the glass replacement, so i would try a new lcd/digi combo, sadly its much more expensive
Pontuação 1
Adicionar a sua resposta
jcandjk1 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 163
