Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
Help identifying small internal part
After being thrown in a pool with my 2 month old 32gb 5S, I completely disassembled to dry/clean it. :( It is currently drying in a sealed container of dessicant. However, while disassembling, at one point I picked up and turned over the back half, and this little triangular(ish) metal piece fell out. I have checked countless disassembly and reassembly guides, pictures, and videos, and I cannot spot it anywhere. Can someone please help me???
http://i.imgur.com/oJgxrjs.jpg
Esta é uma boa pergunta?
Pontuação 5
1 comentário
https://youtu.be/nqVyrhuvF2Y pay attention around 5:50 sec to 6:00 min into the video. I was looking for an answer for a long time. Now you can "see" the answer
por
Adicionar um comentário
3 respostas
Solução escolhida
This is the washer under the screw hole on the top end of the logic board
Esta resposta foi útil?
Pontuação 3
3 comentários:
I just opened up an Iphone 5 I have, and yeah, there it is. :)
What is this parts function Tom? I know from somewhere that it's an important piece.. Does it help the wifi in some way?
por
Which phone did you open? iPhone 5 or 5s?
por
Thanks!
por
It's a spacer, It goes under the very top screw hole of the main board, and aligns up against edge of the top housing, with the longest edge of the spacer near the power button. In the tear down guide refer to step 23 or 27 of the comments, I posted more info there.
Pontuação 2
1 comentário:
Hi Paul,
Can u pl give the full name of the Teardown guide u mentioned, or the link.
Amer.
por
Step 31!!! There are three small pictures, click each one and enlarge! I had NO idea where this thing went!
iPhone 5s Logic Board Replacement
Pontuação 0
Adicionar a sua resposta
zaitsev77 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 4,991
