Ir para o conteúdo principal
O HTC Desire é o primeiro smartphone da série Desire desenvolvido pela HTC.
Why does the network connection break?
After switching on the phone and entering the pin code the home network cannot be found. After some time the network is found but the connection breaks after about 30 seconds. The connection to the network cannot be restored.
The same problem occurs after a reboot. I have tried another sim card of another network provider - same phenomenom.
What do you think?
Maybe it is an antenna problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
- Look at this manual:
http://www.formymobile.co.uk/desiredisas...
The GSM antenna is the small module at the pic 2. Check and clean carefully the contacts (2x).
- Check at the "Settings" - Network connection. If its - manual, change it to automatic.
- Change the network mode to GSM only.
- You can do a factory reset to resolve the problem, if it's software.
If this not help you, ask a specialist for help.
Regards.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jacccooo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 403
