Ir para o conteúdo principal
Lançado em setembro de 2013, identificado pelo número de modelo T100T. Portátil 2 em 1 com processador Quad core Intel® Atom™ e 2 GB de RAM.
How Do I Remove my Broken Screen?
I cracked my tablet screen and I have a replacement. but I cant seem to figure out how to remove the cracked screen. To clarify only cracked the glass (I think its called the digitalizer) not the LCD. Any tips?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
You have the back of the tablet off, unplug everything carefully then heat the frame up (careful to not melt it) and use a safe opening tool to peel the frame off the digi.
Hope this helps!
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks alot! i found sombody on you tube. but i mess up the glue when i went to put the new one into the frame so now it dosent lay flat but it seems to work fine anyways.
por
Jess where did you get the replacement digitizer? And how much did it cost? Thanks! Adam
por
I got mine off of ebay for $57. seems to be working fine so far!
por
Be careful replacing the digitizer on the Asus T100
They do have replacements on auction sites for around $30-80 depending if its being sent from overseas.
I have had terrible luck with them though -- I think they are all faulty.
Out of the 4 I've received (two shipments a couple months apart) 1 arrived cracked, and the three others all start to show "phantom touches" like crazy not very long after install, which totally makes them useless.
btw -- it costs $130 to return them to china with tracking for a $140 refund... lol... they know what they are doing...
Pontuação 0
2 comentários:
that sucks! luckily someone warned me to check where it was coming from an make sure it was from US.
por
Did you ever find a good place to get high quality replacements for these?
por
can someone tell me where i can get a 10.1 transformer screen
daveg002@gmail.com taanx
Pontuação 0
I looked on Amazon first thin and found all supplies needed at great prices. Hope this helps. And "how to" videos on YouTube.
Pontuação 0
Adicionar a sua resposta
Jess Savage será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 28
Ao todo: 13,648
