Ir para o conteúdo principal
O quinto smartphone Google Nexus. Anunciado oficialmente em 31 de outubro de 2013, ele ostenta uma tela 1080p de 4,95", um processador Snapdragon de 2,26 GHz e suporte a LTE. Equipado com Android 4.4.2, KITKAT. Fabricado pela LG.
static image and colorful screen
The problem start two weeks ago, the screen started to fail but the problem it's getting more frequently, if I use my phone for 10 seconds the image get freeze, if I turn off and turn on the screen, it shows a colorful static image like old tv without signal, if I turn off the screen for a minute, when I turn it on again, the phone works well for almost ten seconds and get stuck again but is only de image, the phone continue working with the freeze or the colorful image
Imagem
Imagem
I read that it could be the the part "USB Port Dock Connector Mic Flex Cable" but I want to confirm before buy it
thanks in advance
Note: the second image is not mine, I use one found in a forum but it show the same problem
Esta é uma boa pergunta?
Pontuação 4
2 comentários:
any solutions ?
por
yes, I fixed it changing the flex usb charge port
por
Adicionar um comentário
4 respostas
Left my Nexus 5 for about 10 minutes, took it up to check message and the screen was the same as the second picture. Tried rebooting the phone, however nothing seems to work nor does the rebooting screen comes up
Esta resposta foi útil?
Pontuação 0
My phone started showing that screen with low frequency, now if I keep the display on for one minute the screen show the static-y screen
Pontuação 0
I have the same issue. Looking on forums I found the problem. You need to replace the FLEX USB charge port.
I´m looking on ebay to buy one.
Pontuação 0
Have you fixed it...i have same problem...help
Pontuação 0
1 comentário:
por
Adicionar a sua resposta
Alexander Morales Sevilla será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 2,669
