Ir para o conteúdo principal
display on/off-sensor placement / clamshell mode
Hi .. I want my MacBookpro to run in permanent clamshell mode without needing to close the display. I thought I could just trick the open/close sensor system or so
any idea? where is that bugger, in the hinge?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
Located on the back of the right side of the keyboard, about in the middle.
It is commonly called a reed switch. By sliding a paperclip along the bezel bottom you can locate the magnet in the bezel. Placing a magnet on the top case in the correct position will "sleep" the display.
If this answer is acceptable please remember to mark it.
Good Luck,
N.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Genius. Trying to figure this out for years. Even the IT guys I was working for didn't know.
por
I have a MBP with a busted screen (backlight working). It's hooked up to a studio diplay that is configured as main monitor in system preferences. The MBP display doesn't do a thing now, neither open or closed. No need to trick any sensors.
Pontuação 0
2 comentários:
but is it still in the system prefs? i hate saerching for windows that are located on a second screen thats switched off
por
Once the external display is configured as main all windows are displayed on it.
por
ok .. it seems to be in the screen on the right side of the camera and the little hook thingy that keeps the cover down. attaching a magnet there sends my MacBookpro to sleep
thanks machead3
Pontuação 0
Had this happen on an A1278; couldn’t figure out why. Magnetized USB connectors were the problem. Demagnetize them with something like this: https://amzn.to/2CEM4pJ
There are 4 strong N or S domains on the upper display border by the camera, starting about 2” from the outer edge of the display clamshell and ending about 3-4” inches in, on both right and left sides. This makes me think there’s either 1 or 2 clamshell sensors (hall or reed type) in the palm rest on either side of the trackpad.
pmset -g log:
Display is turned off
Entering Sleep state due to 'Clamshell Sleep' …
Pontuação 0
Adicionar a sua resposta
kay k será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 4,272
