Entire touch screen totally unresponsive on right side of phone.
Hello,
I dropped my iPhone 5 last night with no cosmetic damage to the phone or screen. However, I noticed two vertical white lines and the entire right side of the touch screen is unresponsive. I cannot access certain apps, edit settings, access voicemail archive screen, save alarm clock settings, etc. I did some research and read it may be the digitizer cable, but how do I successfully know if that is the cause? Will replacing the LCD display solve the problem? Please help, I would really like to be able to use my phone again!
Thank you so much,
Stella
Esta é uma boa pergunta?
23 comentários
Hi Stella I have the exact same problem with my iPhone 5. Can you kindly update if you got it resolve and if so how? Thanks in advance.
por Bupa
Hey there! So it was in fact a damaged screen and I ended up replacing the screen with the ifixit kit successfully. I watched the ifixit video a million times and eventually managed to fix the screen perfectly. One thing to note. Be very careful not to strip the tiny screws. That made it much more difficult for me and took me an hour longer to get the parts replaced. There are videos on the internet that help you how to work with tiny stripped screws so don't lose hope if it does happen to you. Another thing to note is I prefer the ifixit replacement screen (it is a bit pricier), but there are a couple of pre-assembled parts on the replacement lcd screen that reduces the process (ie camera housing port pieces are already attached to the replacement screen vs. having to reuse the housing ports from your original phone). The reason why I mention this is because those pieces are very, very small and hard to put back. I hope this all made sense and hope everything works out for you!
por Stella
Thanks Stella. I just dropped my 5S and have the same issue. I can't even get into the phone because one of the numbers on the 'dead' side won't enter for my code. I'll try changing the screen. Mine is only about three weeks old and I died inside when this happened.
por Jude Lockhart
I'm having the exact same problem. Do you have a link to the exact kit you bought to fix it pls? And was it 5s?
por arathecoach
I am having the same problem with my iPod 5 .-. But the entire screen is not working
por shirley Bain
Exibir mais 18 comentários
