Ir para o conteúdo principal
Informações de reparo e guias para o Apple iPhone 5c, anunciado em 10 de setembro de 2013. Modelos: A1532, A1456
How can I fix a keyboard problem?
iPhone 5C keyboard will not type certain letters after screen repair. Everything else works fine except for the keyboard. It wont allow me to use the numbers button. Tried a hard reset. Did not work. What can i do?
Esta é uma boa pergunta?
Pontuação 13
Adicionar um comentário
6 respostas
Solução escolhida
If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive.
But really must try a new known good screen first, as this is still the first suspect.
Esta resposta foi útil?
Pontuação 4
Pergunta mais útil
Sounds like a faulty digitizer to me, or a poorly seated digitizer connector. Did you do the screen repair yourself, or did you have a repair shop do it?
Pontuação 4
4 comentários:
My sreen is smashed but this was happening before i
Smashed it
por Compartilhar
no it was not
por Compartilhar
I had the repair shop to do it.
por Compartilhar
You should tell your shop about it. If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive. But really must try a new known good screen first.
por Compartilhar
Usually, the problem occurs after a screen has been replaced and the digitizer cable has not been seated properly. You have to ensure the correct sized screws fitted into the correct position. There are four screws holding down the shield that covers the display cables and if you mix them up then your shield and cover will not fit correctly and the cable connectors will move and cause digitizer and screen faults. Uisung #000 screwdriver you can easily remove and refit these screws, if you are unsure the bottom two are the smallest (1.3 mm screws) and then the upper left is slightly larger (1.7 mm screw) and the far right screw is the largest of them all (3.25 mm screw). You can prior to the removal use a coloured marker or pen and colour code the screws to the position they belong to, remember the two lowest screws (1.3 mm screws) are the same size so can be coloured the same. This should help resolve any problems with exchanged screens and cabling to screen faults. Thanks guys
Pontuação 2
hello,
this is in relation with touchscreen ic chip when everything is all right...
Pontuação 1
My keyboard is frozen also screen
Pontuação 1
my iPhone 5s I got the screen repaired and the u and n dose not work on the keybord
Pontuação 0
Adicionar a sua resposta
keldavis5 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 31,852
