Ir para o conteúdo principal
O Nokia 5800 XpressMusic é um smartphone com Symbian e dispositivo de entretenimento portátil da Nokia.
Water Damaged Phone Querry
my nokia 5800 xpress music got drowned in a mug of water for 3 to 7 seconds. now its not working. initially it was working a bit like its three bottom line buttons were glowing and it was able to switch on with no display. but now its not even switching on and the three bottom LEDs are also not glowing.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
When you have a water damaged phone you must do this:
- Remove the battery and don't try to switch-on it.
- Disassemble the phone and dry off the water (stay it disassembled for some hours).
- It's good to clean it with an alcohol.
- If you have a magnifying glass, check the mother board and all connectors for oxide.
If this not help you, seek help from a mobile phone technician.
Regards.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Prateek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 514
