My phone only charges when its off
Okay so my phone only charges when its off but when it turns on my phone doesn't recognize that its being charged and then it dies. it comes back to life at 4 percent and dies. its not the cord because I've tried it on 2 different phones and it works perfectly fine on the other two. Again my phone only charges when its off but never when its on.
Esta é uma boa pergunta?
24 comentários
even i am experiencing the same issue.. pllease give me a suggestion how to get rid of this problem
por drashti shah
i have this exact same problem! i've replaced both the battery and charging port but that hasn't fixed it. seemingly randomly (maybe 1/20 charge attempts) will charge the phone to 100%. most attempts only charge the phone just enough to turn on (at about 3-5%) and then the phone crashes within 10 seconds of booting up. in case it matters mine is a 5S.
update: i just had a successful attempt and out of curiosity i turned the phone off and then back one and when it came back on it was no longer charging.
por Christopher Prabhu
I had the exact problem and decided to buy a new charger, which solved the whole problem.
por Nahuza Hassan
Solved: Need Apple brand charger
I had the same issue and tried 3 different chargers. Come to find out it was cheap generic chargers. Once I tested with an actually Apple charger it worked.
por christinewilliams21
Water damage... Same thing happened to my phone- took it to att and apple who said I could get a new phone under warranty however the charging port has damage. They told me it was not something that could be repaired. My phone only charges when it's turned off as well. My screen needs to be entirely black. When I know its about to die (like at 2%) I'll plug it in to the wall charger, and turn on the flashlight and leave it there. The flashlight drains the rest of the battery and the phone will shut down. At that point..leave it! Don't touch any buttons or re-plug the charger back in to make sure you see a battery symbol, that will prevent the phone from charging to 100%. Just trust that it is charging, even without seeing the battery symbol! The screen should be ALL black. I do this when I'm about to sleep..and when I wake up in the AM, unplug the phone and it's at 100%!!!! Before trying this exact method, I could also only get it to turn on to 2% (or 7%) before shutting off.
por Alyssa d
Exibir mais 19 comentários
