Ir para o conteúdo principal
Repair Guides for Dell Desktops.
446 Perguntas Visualizar todos
Upgrade ATI Radeon HD 4200 graphics card in Dell Inspiron 570?
I would like to replace this graphics cord, I already up graded my power supply cord from 300 with a corsair CX430 can someone tell me what graphics cards will work with this power supply I have a AMD Athlon(tm) II X3 435 Processor, 2048 MB DDR3-SDRAM (1333 MHz) with 2.00GBMemory Size , Total Physical Memory: 4.00 GB, Maximum Supported Memory: 8.00 GB, Interface: PCI , Video Card Chip Type: ATI display adapter (0X9710), Video Card Memory: 256.00 MB , and a Operating System Microsoft Windows 7 Home Premium Edition (64-bit), Service Pack 1, DirectX Version 11 and Maximum OS Memory 16.00 GB. DON'T WANT TO SPEND MORE THAN $100 IF THAT IS LOGICAL NEW AT THIS. THANKS TO WHOM EVER CAN HELP ME!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Schwann, something like the XFX HD-667X-ZHF3 Radeon HD 6670 would be the max you could use with your current PSU. It is available for around $70. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanx a lot I really appreciate ur help, is there any thing else you suggest I buy with this, so I don't run into any problems considering my computer specifications.
por
Schwann, I think you got is pretty much covered. That setup should serve you well for a while.
por
Adicionar a sua resposta
Schwann será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,134
