Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Perguntas Visualizar todos
Anyone tried removing/replacing individual keys?
I have a client with a "sticky" spacebar. I am hesitant to remove the key for cleaning for fear of either breaking the key/assembly, or not being able to get the key back on properly. I've done this countless times on previous models, but give the uniqueness of this machine I thought it may be beneficial to ask first. Thanks!
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
No different than the others.
Apple so far has removable key caps (including the space bar) across all of their laptops so people can swap out the caps for a different language set.
Here's a good Youtube on how: How to remove and clean Macbook Pro keyboard keys
Hope this helps
Esta resposta foi útil?
Pontuação 4
Tried to remove the backspace, enter and shift keys and resulted in the clips breaking and have to order new keys.
Hope this helps
Pontuação 2
3 comentários:
Where did you order your individual keys?
por
Give these folks a try: TheBookYard
por
Thank you Dan for sharing this info and geni499 for asking.
por
Adicionar a sua resposta
Grillwrecka será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 30,585
