Ir para o conteúdo principal
iPod charging but not fully...
When I plug it in, it shows a red sliver of battery and a lightning bolt. After a while, it boots into the OS. The problem is that it warns you there's less than 10% battery left and the battery icon no longer shows a lightning bolt. I can't get the battery to keep charging. Does this mean the battery's at the end of its life?
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Ok, I just got a better theory. I peered into the dock port down there and found that the little circuit piece is wobbly and one of the pins (it looks like #1 or #2) has been pushed into the back wall and bent up.
por
I've also found out that pin #1 and #2 are grounding pins. So maybe this explains why it charges at first but stops once it boots up? I guess the OS checks for the pins and manually stops the charging if one of them is missing? Now.. if I could find a software fix for a hardware problem, that would truly be amazing.
por
Adicionar um comentário
1 resposta
Solução escolhida
I would bet dead battery. you should be able to change it, if using one of the guides... it is an old device, battery is nearing its end anyways...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
AndrewNoNumbers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 1,661
