Ir para o conteúdo principal
With the exception of the Xbox game console itself, video game accessories can be anything from the controllers, memory, power adapter (AC), audio/visual cables, and more.
How to fix just x-axis of right analog?
My Xbox 360 Wired Controller right analog's x-axis is not working. I have checked the potentiometer that works on the x-axis. It's not changing resistance as the one for the y-axis or the two others for the other analog stick are. When I connect the controller to my pc and run x360ce, it shows an initial value on the x-axis and then it reduces to zero without taking any further feed back. When I clear the axis and reassign it, it automatically picks it up. So what I am saying is it has an initial value that is getting picked by the app. Then it reaches zero and refuses to change again.
How can I fix the potentiometer? Or is there something else I should check first? I have opened up the controller.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
It looks like the potentiometer is giving a very small immeasurable change in resistance.
por
I am having the same issue. Do you have any fix as yet?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sherjeel Shabih, the only way to repair this is by replacing the analog stick.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I have some old playstation 2 analogs lying around. Will they fit? They seem to be the same. Is there a way to check the resistance range on the potentiometers without connecting them to a supply? Or someway to do it with an external supply?
por
I do not believe that those will fit, but of course you can try. You will not need a power source to check the resistance of a potentiometer. All you need is a multimeter with an ohm scale. https://www.youtube.com/watch?v=DJtV5PH2... good example
por
Adicionar a sua resposta
Sherjeel Shabih será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 5,481
