Ir para o conteúdo principal
O BlackBerry Z10 é um smartphone baseado em tela sensível ao toque, desenvolvido pela BlackBerry, anteriormente conhecida como RIM.
replace non working camera
Internal camera not focusing. Two thread size purple haze across image on rear facing camera. Unable to focus. Front camera clear. Phone dropped often. No lense damage visible. No cracks visible. Purple haze looks like internal cracks?
Esta é uma boa pergunta?
Pontuação 6
4 comentários
not working camera
por Compartilhar
Yes it's. My BlackBerry camera has stopped working more than a year.
por Compartilhar
happy if it be fixed
por Compartilhar
I got it fixed but now it captures low quality images
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
frank, I would download the BlackBerry Virtual Expert from BlackBerry World or go into Help and select Testing, which will allow you to use BlackBerry Virtual Expert without downloading it. With that you can test each feature in your BlackBerry Z10. Check both of the cameras with that. Also make sure that your software is updated. If your camera should be faulty use this teardown to see what is involved in changing it. The camera is not very expensive and can be purchased from places like this as well as many others. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
frank será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 2,402
