Ir para o conteúdo principal
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
20 Perguntas Visualizar todos
Where can I find power supply adapter for Ikea Spoka?
My power supply of the Ikea Spoka lamp is busted. It has been proven !@#$ to try to find an adapter that is specifically designed to output 4.8V DC and 400mA - too specific for Google, I assume. I tried the Ikea website but they don't seem to sell replacement parts.
Grateful if someone can point me to a website where I can get a similar power supply for the LED lamp. Love the lamp, don't want to just discard it.
Many thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Simon Wing Tsuen Ho, just checked the instruction manual for the SPÖKA LED night light and 5V 500mA will work just fine. Biggest issue will be to match the barrel adapter. As in suggesting a website, that will depend on where you are located. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
7 comentários:
Thank you for your prompt response! Is there any website I can find that will ship to the States?
por
If you are in the US go to any of the major department stores and purchase a universal adapter. Those come with variable voltages as well as various interchangeable barrel adapters
por
Thanks oldturkey03. Unfortunately I don't get to go to department stores that easily because I work on ships and I'm always stuck. Buying from websites and have them sent to the ship address is the best route to go for me.
por
Something like this http://www.amazon.com/PowerLine-Compatib... should work for you. Amazon does ship as well:-) If that does not work for you, measure the barrel on your lamp and let us know what size it is. I have plenty of those and do not mind shipping it to you.
por
Thanks! That's what I need to look for!
por
Exibir mais 2 comentários
Adicionar a sua resposta
Simon Wing Tsuen Ho será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 45
Duração total: 14,056
