no starting tone just the apple then lightblue screen
It turns on and gets lightblue and nothing more just stops before the apple logo and the spinnging wheel. What is the problem?
Esta é uma boa pergunta?
Have you looked here?
Could be bad directory on disk try the /sbin/fsck -fy startup:
1. Start up in single-user mode by holding Command-S after restarting the computer. Note that single-user mode always uses the US English keyboard layout.
2. Type these commands, each on a single line followed by Return:
/sbin/mount -uw /
3. If the computer responds with "System Modified" type(run) /sbin/fsck -fy again until it stops modifying the system files. Then type
rm -rf /System/Library/SystemConfiguration/ApplicationEnhancer.bundle
reboot
4.If the issue persists, use option A or B from here.
Good Luck,
N.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,708
