Ir para o conteúdo principal
Upgradable RAM and capacity
I've got this laptop and I've been looking around and have found guides to upgrade the ram from 1GB to 2 but I don't understand the guide I saw on this site. Do I need to buy 2 of the chips? And are the chips already in there 500mb each? Please explain!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Otto, not sure what memory modules you have in your computer, but yes most likely you have 2 500mB Ram to make up 1GB. To get it to 2GB you will have to replace both of your modules with a 1GB module each; buy two modules to replace your two. The modules itself depend on your processor:
Here are part numbers for the memory modules
For use only with computer models using Intel processors:
1024-MB 434742-001
512-MB 434741-001
256-MB 434740-001
For use only with computer models using AMD processors:
1024-MB 431403-001
512-MB 431402-001
256-MB 431401-001
Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Otto será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 337
