Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Tabs on digitizer broke
Please help. I purchased two digitizers and have broken them both when pulling the cables over to fit. On the phone I'm repairing the tabs were much longer. What can I do to correct this,it's actually the digitizer cable that I've broke twice,
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi there this is the most important and tricky bit of the install just make sure when ur feeding the cables through not to pull them and the digitizer cable has a thicker end at the bottom of it once the start of that thick end is through the frame it will all slide in nicely
Esta resposta foi útil?
Pontuação 1
just watch dome youtube videos. By the way you have to insert it in the slot while you rotate the screen.
Pontuação 0
Adicionar a sua resposta
Rod será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 62
