Hi there,
It has been a week that i bought an iPhone 5. It has error 9..4014...3007...and with black screen.
But! Right now at 27/08/14 12:09am it's unlocked :D.
1) First no need to go on DFU mode, it's already on just by checking with tinyumbrella "log". it says "DFU device connected". => then close tiny.
What i will talk about is not "THE" solution, because ERROR 9 is from everywhere...
**some ppl would tell about changing front camera flex wire, plug off camera wire while restoring, change charging port, put on DFU mode...etc etc etc...*
2)About my computer :
_I put it on ethernet so no wifi. I use win 8 x64. *i have tried on XP, Win7, Win8, macbook 2014 retina and macbook i5 2013
_Install itune x64
_I've closed all apps
_Checked if host file was good
_Download firmware 7.1.2
3)About my iPhone 5
I went across a lot of site about error 9 iphone 5/5S/4/4S....
_I changed the charging port
_changed the battery
_changed The front camera
_Changed usb wire
4)Process
1_Unistall then install itune.
2_Reboot computer
3_Plug in your iPhone. Itune pop up with "a recovery device .....detected...etc"
4_Do 2 or 3 "hard reboot". *If i did not do this error 4014 will pop up
5_Each time you hard reboot, don't forget to push ok on itune
6_Shift+restoration then select your firmware.
7_And what you need is to try this 1,2,3,4....10 times until it get better!
Don't know if this will work for everyone, but i hope it will !
Error 9 Resolved.
9 comentários
I just went through this with my iPad. Tried a dozen times on 3 different machines (2 PC, one iMac) but the error(9) persisted.
I tried this method: https://support.apple.com/en-us/HT204275
...but no luck. I finally took it to an Apple store. They said the update 'revealed a hardware issue'.
THAT IS ABSOLUTE BULLSHIT. THE IPAD WORKED FINE BEFORE RUNNING THE UPDATE.
por mgretzinger
change battery,remove camera,lcd, and try again to restore
por Anirudh kumar
This one works for my iPhone 5s: make sure the battery is full. Open iTunes in your PC, connect your iPhone in DFU mode. Click "restore", it will restore and update your device. The apple logo and progress bar will now appear in your phone. At 60% level, the phone will suddenly black out and the connection in your iTune will seem lost. Wait. The apple logo will reappear and will continue. It's all restored. Hope it will help.
por sramixx
is there any solution yet? my iphone5 got the same issues too .
por Grace Dela Cruz
The iphone has a malfunction on the lcd screen. You need to disconnect the lcd screen. And repeat the same as you did in the video... I know... It is strange but it works. For help check youtube how to disassemble the screen. Its realy easy. Good luck
por Krisjan Slagboom
Exibir mais 4 comentários
