After screen repair, digitizer not working. What next?
Replaced logic board and another new digitizer. Still not responding .
Esta é uma boa pergunta?
You probably have the wrong version digitizer. Check the cable of the original glass and look at the revision.
Esta resposta foi útil?
You're right! Got the same thing, mixed up revision versions and the digitizer did not respond to anything. Worked again when I matched rev 0.0 with another rev 0.0
where did you find the one that said rev 0.0?
Got it off eBay by a Dutch member called ts-shops for 27,50 euro
I have a tab t555 and same issue. where can I get a rev 0.0. or what if I change the connector on the board?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 2,512
2 comentários
my grandson damaged the digitizer on the tab2 can this be fixed or replaced???
por Barbara
How would one go about getting a digitizer with the correct version.
por Stephen Hood
