Ir para o conteúdo principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 Perguntas Visualizar todos
After screen repair, digitizer not working. What next?
Replaced logic board and another new digitizer. Still not responding .
Esta é uma boa pergunta?
Pontuação 0
2 comentários
my grandson damaged the digitizer on the tab2 can this be fixed or replaced???
por
How would one go about getting a digitizer with the correct version.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You probably have the wrong version digitizer. Check the cable of the original glass and look at the revision.
Esta resposta foi útil?
Pontuação 2
3 comentários:
You're right! Got the same thing, mixed up revision versions and the digitizer did not respond to anything. Worked again when I matched rev 0.0 with another rev 0.0
por
where did you find the one that said rev 0.0?
por
Got it off eBay by a Dutch member called ts-shops for 27,50 euro
por
I have a tab t555 and same issue. where can I get a rev 0.0. or what if I change the connector on the board?
Pontuação 0
Adicionar a sua resposta
Corina será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 2,501
