Ir para o conteúdo principal
Tablet de 7" da HP lançado em abril de 2013, com algumas melhorias em relação às primeiras iterações. O reparo deste dispositivo é semelhante ao de outros tablets Android, exigindo apenas chaves e uma ferramenta de abertura. Disponível nas versões de 8 ou 16 GB / Vermelho ou Prata.
How can I replace my screen?
The touch screen does not recognize my finger movements very well. Is there anyway that I can replace the screen or fix the touch screen so I can use it seamlessly?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Where can I buy a new screen?
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Sometimes the touchscreen has a slight amount of lag due to an overload on the system, much like people who need sleep after a long day. Before just replacing the screen, try doing a hard restart by holding down the power button for 10 - 20 seconds or until an HP logo pops up.
If that still does nothing, then part of your touchscreen may be defective; however, replacing a certain part of the screen is extremely difficult to do, so I suggest buying a new screen assembly and using the HP Slate 7 screen replacement guide to help you along. Another option is to contact HP support, inform them of your problem, and they will tell you what needs to be done from there.
Esta resposta foi útil?
Pontuação 4
you can order the replacement on ebay for 23 bucks, in youtube you can find info about how to replace the screen, my iphone 4s would not slide for nothing, i order the new screen and the digitizer as well, still is not working, all the buttons work, but just is not sliding for unlock, is stuck on the welcome screen, sad...
Pontuação 0
Adicionar a sua resposta
Raj Parekh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 29
Ao todo: 2,907
