Ir para o conteúdo principal
Laptop HP de 15" com processador dual core AMD Phenom II de 2,60 GHz.
gpu reflow and black screen
hi there i have hp pavilion g6 series . . i have black screen problem , after searching known that the problem is in gpu chip .. and i was made a reflow for gpu chip and the problem fixed :) >> but i always need to reflow the gpu and if i shutdown the device .. to open it again you must remove the motherboard and make reflow for gpu after that the device work ... this a too bad to do this everyday :( ... can any one suggest anther way ?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Yes, you need a new GPU chip. Your reflow effort is not really repairing the root issue. Sadly, removing the old GPU & re-balling a new GPU for this system may not make economic sense.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
alwerdani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 2,204
