Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Perguntas Visualizar todos
Replaced LCD Now have Black Screen
I was repairing the LCD on a Iphone 4 CDMA and unplugged the LCD connector before the battery. I hooked it back up and the screen was black. The phone was on you could see the back light and you could hear it. I tried two other screens and the same except the last one the screen was a little gray. Did I do permanent damage to the logic board? I have tried the reset and it did not work.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
The iPhone is not so vulnerable.
You can try to unplug and plug the connector of battery.
Esta resposta foi útil?
Pontuação 0
1 comentário:
yes like stated installed two more LCDs and none of them worked. I have see on repair videos a warning about unplugging the LCD first could cause damage want to know if this is true what damage has been done.
por
Is your iPhone iOS 5 If so then you will need to update to iOS 7 and the screen will work..
New screens don't work on iOS 5
Pontuação 0
Adicionar a sua resposta
Kage será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 147
