Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
little inductor broke off logic board, not the blue coil
hello,
2 little pieces have broke off the logic board.
They're located here
and the little one next to it
could that be the reason i can't get a signal?
keeps searching or no service..
Could it be soldered back on and if yes, what are the names of the inductors?
thanks a lot
Updated image
Esta é uma boa pergunta?
Pontuação -1
4 comentários
saartje de prijck, your images are a bit to blurry to properly identify your components. Any chance you can post clearer images?
por
thank you so much :)
por
0[image|344932]
is this one better?
i know but i had to resize them :/
por
Thank you for accepting my answer. Sorry, I could not see your image:-)) I added it to the original question since Comments does not allow you to add images.
por
Adicionar um comentário
1 resposta
Solução escolhida
saartje de prijck, your images are a bit fuzzy:-) See if this will answer your question.
U3_RF is a RF1642 in a QFN12 package
U21_RF is a 824-2170MHZ filter in a 0402 package. It appears to be one of Murata's "Chip Multilayer LC Filters (BPF)". Something like this most likely.
c46_RF is a 6.3V 10UF 20% capacitor in a 0402 package
Yes, it is possible that these missing components are part of your problem. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
saartje de prijck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 324
