Ir para o conteúdo principal
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
How to fix wifi and Bluetooth issues?
Hi all. Hope you can help me fixing my HTC one x. It dropped on the floor and wifi and Bluetooth doesn't work anymore. Do you know where wifi and Bluetooth chips are so i can buy the right component to fix the phone? Thanks for your answer. Have a good day!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Looking at the back of the phone, press in the upper right hand corner and hold it there, see if you can get a signal. A quick simple fix for this without opening the device can be to get a plastic hard case and something as simple as a puzzle piece, insert puzzle piece into upper right corner of case, ensure doesn't block camera, and insert phone, see if this doesn't help. Sound weird? Here's proof http://www.youtube.com/watch?v=z8Ha8tkiJ...
Other than that I would suggest opening up the phone and ensure all cables are connected and seated correctly
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for tour help. The phone has an hw problem for sure. Before buying a broken one x to fix mine, I have to know which is the component to replace. Where WiFi and bluetooth chipset are ? On the mono ?
por
Here's a few options that you could do:
1. Go on your local buying/selling website (America is Craigslist) and try to find a broken HTC One X, maybe they're selling cheap because of a cracked screen. Just stay away from any Water damaged ones.
2. Go to Ebay and look for specific parts, if you don't want to do it yourself, save yourself the trouble and buy the parts (which makes it cheaper on you) and bring it to a local shop and they'll replace it for you.
3. If all else fails, you'll have to take it to a repair shop. Make sure the repair shop is reputable so you're not being screwed over in anyway possible.
Pontuação 0
Adicionar a sua resposta
Andrea será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 4,953
