Ir para o conteúdo principal
O Galaxy S 4G da Samsung é um smartphone operado com Android 2.2 que possui tela tátil AMOLED de 4 polegadas e processador de 1 GHz.
62 Perguntas Visualizar todos
freezes up when I turn it on
My Galaxy S4 froze up while in use yesterday, I couldn't turn it off. I took out the battery and put it back in, it powered up but froze part way through loading. I swipe to unlock the screen but it doesn't unlock. Any ideas? I appreciate it.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I called Verizon and they helped me fix it over the phone, I took out the batter, took out the memory card. put back in the battery. Turned it on and was able to hit the settings, More, Application Manager, deleted Zedge and a few other apps, (he said they could contain viruses), cleaned out some caches...and wow, it worked again!
por
Thanks Gary, I appreciate your taking the time to answer and if it does freeze up again, I will try your solution. Tnanks again.
por
Adicionar um comentário
2 respostas
Solução escolhida
Assuming that you still have no response and still cannot get a refresh to work or the battery removal doesn't solve the trick you may need to do a factory reset. Try this:
1.Turn the power off. If your Samsung Galaxy S 4G is frozen, pull the battery out and reinsert it
2.Hold the Volume Down button
3.Press and release the Power button
4.You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5.Select Clear Storage by pressing the Volume Down button
6.Press and release the Power button
7.Now simply confirm your decision: Volume Up for YES and Volume Down for NO
Know that everything will be wiped clean however. If you need any further help please ask.
Esta resposta foi útil?
Pontuação 0
1 comentário:
thank you for your help
por
welLL I HAVE A GALEXY 4G AND IT JUST TURNS ON WITH THE GOOGLE ICON ,THAT JUST STAYS FROZEN I TRIED THIS METHOUD THE VOLUME DOWN BUTTON BUT IT DOESNT FUNCTION
Pontuação 0
Adicionar a sua resposta
auggieaz3015 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 484
